USA Transit Recalls & TSB's
Postby paul2012 » Fri Aug 28, 2015 7:31 pm
As we have a few members on here from the US .
Here are the Recalls & TSB list for the new USA Ford Transit :wink:
Recalls
14V708000 FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY: MOUNTING
Ford Motor Company (Ford) is recalling certain model year 2015 Ford Transit vehicles manufactured July 28, 2014, to August 7, 2014.
In the affected vehicles the fuel filter bracket mounting may detach from the frame cross member over time.
A separation of the fuel filter from the cross member will disrupt distribution of fuel to the engine, thereby inducing an engine stall. An unexpected engine stall while driving increases the risk of a crash.
15V402000 SEAT BELTS
Ford Motor Company (Ford) is recalling certain model year 2015 Transit vehicles manufactured March 1, 2015, to April 10, 2015.
The affected vehicles may have been built with seat belt assemblies that have seat belt labels that are missing the required belt model and model year and instead state "prototype sample."
As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) 209, "Seat Belt Assemblies."
In the event of a safety issue with the affected seat belts, the vehicle owner may not be able to identify the seat belt if the seat belt label does not include a date of manufacturer.
14V482000 SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:DISC:CALIPER
Ford Motor Company (Ford) is recalling certain model year 2015 Transit vehicles manufactured April 3, 2014, to May 27, 2014.
Brake fluid may leak from the brake hose/caliper junctions at the rear of the vehicle. A brake fluid leak may lengthen the distance needed to stop the vehicle.
If both of the rear brake junctions leak, there may a complete loss of braking. Either of these scenarios increase the risk of a crash.
14V483000 STRUCTURE:BODY:DOOR
Ford Motor Company (Ford) is recalling certain model year 2015 Transit cargo vans without rear seating positions manufactured March 12, 2014, to June 24, 2014 and equipped with windowless sliding doors.
The affected vehicles may have been manufactured without the epoxy reinforcement on the windowless sliding doors. A sliding door without the epoxy reinforcement has an increased potential of unlatching in certain side impact crashes.
A door that unlatches may open, allowing for a vehicle occupant to be ejected in a crash, increasing the risk of injury.
TSB -Technical service Bulletin
44642 DIGITAL INSTRUMENT PANEL
FORD 2015 TRANSIT: LOW LEVEL INSTRUMENT CLUSTERS FAILS TO DISPLAY TRANSPORT MODE STATUS, WHEN ITS TO PREVENT REMOTE KEYLESS ENTRY (RKE) AND INTERIOR LIGHT(S) FROM FUNCTIONING WHEN IGNITION KEY IS OFF BUT ENGINE RUNNING.
44983 ENGINE AND ENGINE COOLING:COOLING SYSTEM:HOSE
FORD 2015 TRANSIT 3.2L: BULLETIN INFORMATION INVOLVING ENGINE LIGHT FOR REDUCTANT PUMP AND REDUCTANT LINE HEATER, AND INCONSISTENT WIRE INSULATION.
15B09 LATCHES/LOCKS/LINKAGES:TRUNK LID:LOCK
FORD 2015 POLICE INTERCEPTOR SEDAN VEHICLES: CUSTOMER SATISFACTION PROGRAM REGARDING ENABLE POLICE MODE TRUNK RELEASE. THE PROGRAM WILL BE IN EFFECT THROUGH MAY 31, 2016
44960 SEATS:FRONT ASSEMBLY:RECLINER
FORD 2015 TRANSIT HIGH ROOF BUS/WAGON : SERVICE INFORMATION REGARDING VEHICLES HEADLINER THEAT DOES NOT STAY SEATED AT THE C AND HALF PILLAR TRIM
45019 SUSPENSION:REAR
2015 FORD TRANSIT: BULLETIN INFORMATION INVOLVING TRANSIT VEHICLES EXPERIENCING A REAR CLUNK, SQUEAK, RATTLE NOISE, WHILE TURNING OVER BUMPS
44863 VISIBILITY:POWER WINDOW DEVICES AND CONTROLS
FORD: NO SERVICE ACTION IS RECOMMENDED FOR THIS CONDITION. PLEASE USE AT YOUR DISCRETION.
VARIOUS 2010-2015 VEHICLES MAY EXPERIENCE A TURBULENCE NOISE, SIMILAR TO AN HELICOPTER NOISE, AT HIGHWAY SPEEDS WHEN THE REAR DOOR WINDOW(S) OR SUNROOF
45023 ENGINE (PWS)
FORD 2015 TRANSIT: INFORMATION INVOLVING 3.2L DURATORQ-TDCI: VEHICLES EQUIPPED WITH 3.2L DURATORQ ENGINES BUILT ON OR AFTER 3/6/2015 MAY SET LOW PRESSURE FUEL SYSTEM SENSOR CIRCUIT WHEN THE KEY ON ENGINE OFF SELF TEST PERFORMED
15-0074 ENGINE (PWS)
FORD 2015 TRANSIT: BULLETIN INFORMATION INVOLVING CERTAIN TRANSIT VEHICLES BUILT BEFORE 3/30/2015 MAY HAVE VARIOUS DRIVEABILITY AND CHECK ENGINE LAMP CONCERNS WITH TROUBLE CODES STORED IN THE POWER CONTROL MODULE
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
