cjwilson1988 wrote:Got a pair on ours, love them, huge difference in wind noise and only £50 dealer fitted option. Keeps saying image too big or id add a pic of them
cjwilson1988 wrote:I think i may have cracked it and finally edited it down to a suitable size
cjwilson1988 wrote:Cheers fella, wanted it to stand out a bit, would have got another sport but dont do them on mk8, had them fitted from day one so not sure on speed of windows, but they do seem a little slower than on the mk7
oliver.vd wrote:Hi guys,
We stock the Genuine MK8 wind deflectors from Transit at slightly less than the RRP (http://www.vandemon.co.uk/product/wind- ... rs-vy3044/). The wind deflector will effect the speed of the window as they fit into the window channel but this is usually easy solved with WD-40 or similar down the vertical edge. Once they've been fitted for a while (i.e. a couple of months) and have worn in, they're fine.
Cheers,
Oliver
Damien89 wrote:As per title, has anyone put wind/rain deflectors? Because when the windows are down too much wind enters the cabin and when its raining to much water enters the cabin even if the windows are lowered just a tiny bit.
cjwilson1988 wrote:Damien89 wrote:As per title, has anyone put wind/rain deflectors? Because when the windows are down too much wind enters the cabin and when its raining to much water enters the cabin even if the windows are lowered just a tiny bit.
Did you get some fitted in the end mate. Ment to ask sooner but had a lot on
