Euro 6
Euro 6
Postby Clevelander » Mon Feb 01, 2016 4:07 pm
Hi
New to the forum and straight in with a question I'm afraid !
I order a new mk8 transit last week only to have the dealer call today and say he can only get them in euro 6 2litre .
After having trouble with my first off line mk7 I don't want to be a Guinea pig again .
I'm not a Petrol head so please be gentle with me ..
What's the pros and cons of the euro 6 ?
Thanks in advance for any help .
Clevelander
Re: Euro 6
Postby Damien89 » Mon Feb 01, 2016 7:45 pm
You would have to start filling with Adblue.
Damien89
Re: Euro 6
Postby Clevelander » Mon Feb 01, 2016 8:04 pm
Thanks Damien
I'd not even heard of adblue until I just googled it .
I was curious as to wether euro 6 had any effect on service intervals and cost along with mpg .
Clevelander
Re: Euro 6
Postby Damien89 » Mon Feb 01, 2016 8:47 pm
Clevelander wrote:Thanks Damien
Actually it does have an effect on service cost. As the oil for euro 6 is higher in price than the euro 5 oil. My minibus 2015 h3 l3 2.2 155bhp uses 1 full tank of adblue (21 litres) every 3000 miles approximately.
Damien89
Re: Euro 6
Postby V184 » Mon Feb 01, 2016 10:20 pm
think i would take a punt on the 2 litre, it might use less adblue as its "designed" for euro6 & they may have sorted the gearing out as well
V184
Re: Euro 6
Postby moley551 » Wed Feb 03, 2016 12:53 pm
That much adblue seems excessive, average use is about 1liter per 1000 miles depending on vehicle usage...7 times average seems very high
"Don't find fault, find a remedy"
H. Ford
moley551
Re: Euro 6
Postby V184 » Wed Feb 03, 2016 6:32 pm
Perhaps there having to flood the exhaust with adblue to get the emissions down ?
V184
Re: Euro 6
Postby Damien89 » Wed Feb 03, 2016 10:54 pm
I'm pretty sure that all minibuses are using the same amount of adblue approximatelly. I think ford is using that much adblue to keep the dpf from filling up with soot. One thing i noticed is that every 2 days the vans does a regen, not your normal regen where white smoke comes out of the exhaut, just a routine regen to prevent the dpf from clogging up with soot.
Damien89
Re: Euro 6
Postby moley551 » Fri Feb 05, 2016 9:26 am
From various sources adblue usage is between 4-6% of fuel used, so a 21ltr tank is only going to do 3,000 miles at 30mpg not the 1 liter per 1000 I found quoted previously.....
H. Ford
moley551
Re: Euro 6
Postby Damien89 » Fri Feb 05, 2016 8:34 pm
moley551 wrote:From various sources adblue usage is between 4-6% of fuel used, so a 21ltr tank is only going to do 3,000 miles at 30mpg not the 1 liter per 1000 I found quoted previously.....
So my minibus is using the average consumption of adblue.
Damien89
Re: Euro 6
Postby moley551 » Sat Feb 06, 2016 3:34 pm
Yes it seems that way. 1% was quoted for a 180ps puma based engine in a Jaguar car.
H. Ford
moley551
Re: Euro 6
Postby 155L3H2PANEL » Mon Feb 29, 2016 6:41 pm
my 155 l3h2 rwd uses the full tank every 3000 miles.
I only get 17.5 mpgs as well.
Any body getting better than this? Ive spoken to a guy who has a rwd 125 l3 h2 euro 5 (no adblue) and he boasts high mpgs into the 30's and excellent power. I have none of these things.
I've also got juddery accelerating often in most gears. 6th is useless. I can't break the 90mph barrier in any gear.
Ive given up on any help from dealer pretty much.
155L3H2PANEL
Re: Euro 6
Postby Damien89 » Mon Feb 29, 2016 8:40 pm
155L3H2PANEL wrote:my 155 l3h2 rwd uses the full tank every 3000 miles.
17.5mpg is way low, my 17 seat minibus is getting 21-22mpg in stop and go driving. (euro 6)
What do you mean by juddery acceleration? (vibration?)
Damien89
