I run a mobile tyre company and ever since I'v had my mk8 I've had problems running the inverter in it.
If I have smart charge plugged in it keeps overpowering my inverter and it goes into over volt protection mode and cuts power to my machines.
If I unplug the small single wire plug, Battery light illuminates and I don't get enough power through to the inverter (around 13v and drops to -10v underload)
as you can imagine this is causing real problems for me.
I'm going to try swapping the marine battery I have with a silver one as recommended by ford and see if this helps.
I suspect the single wire plug may just be cutting out the sensor and not the smart charge system itself
I've read about the 3 pin plug but can't find it and not sure if its one of the other wires to the alt (its a bit awkward to get at so I want to be sure I'm doing the right bit)
TIA
Mike
[/URL]
