Lurchersand1cat wrote:I usually use a Ventlock on my van for ventilation unfortunately my new van won't lock my van at all if any of the doors are open. Can you knock the sensors off and still lock the van up with door securely open
Frag wrote:If you manually close the latch on the relevant door,van will lock...
Surely if your using a ventlock,the latch will be in the closed position and therefore van will lock as normal ??
