new van .. do you REALLY need to fit extra locks
Postby citrus » Tue Jun 07, 2016 4:47 am
so getting a new van and being suggested that I pay extra for a slam lock for the side door and perhaps an extra deadlock for the rear doors.
anyone else done this and think it was worth it ?
i am NOT a courier so perhaps the slamdoor for the side isn't worth it
but when I am carrying expensive mountain bikes ... I might be grateful for the extra dead lock on the rear.
what say you forum experts ............... ??
citrus
Re: new van .. do you REALLY need to fit extra locks
Postby mavericktc » Tue Jun 07, 2016 10:14 am
Depends on where you live.
mavericktc
Postby loot » Tue Jun 07, 2016 10:30 am
It's always worth adding security to your van regardless, the type and cost of it is the question tho.
There are actually some simple and cheap methods of securing your van so have a look and weigh up the cost of different methods.
Also consider that the upgrades when you are buying the van may not be the same price if you decide you want them after you have it. :wink:
Ids map here
loot
Postby citrus » Wed Jun 08, 2016 8:37 am
In london so might just do it
here is what the dealer says
"By double pressing the lock remote it dead locks the doors as standard .
But if you still want to fit slam locks £95 a door (load doors only)"
my question is the standard deadlock ...was hoping Ford would have sorted out the deadlocks and as standard in a MK8 they would be really good by now...
so adding an additional 2nd deadlock to the rear door ...is this overkill ?
citrus
Postby ake » Sun Jun 12, 2016 10:47 am
Adding independent locks is never over kill
Postby moley551 » Sun Jun 12, 2016 11:20 am
Check out YouTube, with a bit of knowledge they can unlock your van and disable the alarm before it goes off, less than 14 seconds and all doors are unlocked and alarm disabled.
Will try and find the link
viewtopic.php?f=65&t=167845
"Don't find fault, find a remedy"
H. Ford
moley551
Postby moley551 » Sun Jun 12, 2016 11:47 am
Link to alarm being disabled via OBD, in this case they are after the car, for vans without push button start, they have gained access to your cargo.
https://youtu.be/dvmSOEKfkug
H. Ford
moley551
