Eastcoast wrote:Thanks, I thought they had issues with oil pumps? I sat in one today and tbh it is nothing like the mk7, seats are thin and dash looks like it's from a fiesta on steroids! The loom to rear lights etc is mounted in a plastic trunking, which is a good idea to protect wires but it's mounted within the load area, you'd have though it would be behind the structure work.?
Test drive this weekend
Damien89 wrote:Eastcoast wrote:Thanks, I thought they had issues with oil pumps? I sat in one today and tbh it is nothing like the mk7, seats are thin and dash looks like it's from a fiesta on steroids! The loom to rear lights etc is mounted in a plastic trunking, which is a good idea to protect wires but it's mounted within the load area, you'd have though it would be behind the structure work.?
Early 2.2's had oil pump failures, yep seats are rubbish, its like sitting on a plank and yes mk7 dash has more storage space.
Eastcoast wrote:Well, test drive... It's a little more civilised than mk7, no faster, steering is numb, it still feels cheap inside
Salesman was honest when asked, yeah they have issues, engine, electrical niggles and ford want every box ticked before they'll authorise remedial work under warranty.
I've had trannys from the mk2 on and tbh if I could buy a brand new smiley 2.5di I would.
I'm so unimpressed and tired of faults with current van I'm trying a sprinter next week, even though it's 5k more.
Damien89 wrote:Eastcoast wrote:Well, test drive... It's a little more civilised than mk7, no faster, steering is numb, it still feels cheap inside
Sprinter maintanance costs much more than ford's
Eastcoast wrote:Think the servicing will prob work out even in long term.
The main issue is reliably and going by the number of issues on the Internet for trannys v sprinters you wonder what's going on, Are sprinters as bad just not documented?
My current mk7 needed it's diff bearings replacing at 37,000, Dealer wanted to help but ford flatly refused to offer any good will as it was just couple of weeks over the 3 year warranty, £2,800 bill.
Brake lights kept blowing fuse, £100's spent at dealers tracing fault, no luck. I eventually found steel plate above cabin was cutting through loom on n/s thanks to advice off a forum member.
its now surging at tickover, suspect PRV valve or worn injectors but no fault codes, it's done just 74,000 miles.
Eastcoast wrote: Are sprinters as bad just not documented?.
Mike wrote:Eastcoast wrote: Are sprinters as bad just not documented?.
Correct, there isn't a Mercedes Sprinter forum so the complaints are spread more thinly than the Transit complaints.
