mk8 engines
mk8 engines
Postby motovanner » Tue Jun 20, 2017 1:28 pm
do the mk8 vans use the same engines as the late mk7 s did?
what engines and power outputs are available on the mk8 from year 2014 onwards for fwd versions?
many thanks for any help.
Facebook/All tents Camping Group
motovanner
Re: mk8 engines
Postby loot » Tue Jun 20, 2017 11:26 pm
Puma 2.2 tdci euro 5 then temporary puma 2.2 tdci euro 6 with adblu added (power outputs 100ps/125ps/155ps) til 2016 then introduced dw psa 2.0 (diesel) engine euro 6 with power output 130ps and 170ps.
Something like that :o
Ids map here
loot
Re: mk8 engines
Postby motovanner » Wed Jun 21, 2017 9:41 am
cheers loot! exactly the info i needed -))
motovanner
Re: mk8 engines
Postby Willjmay » Thu Jun 22, 2017 3:16 pm
The new 2.0l engine is a brand new euro 6 engine developed in Dagenham. It's code name was Panther. It is not a PSA engine.
In the new tranny it has 3 maps with 105, 130 and 170 bhp - identical components in all 3
Willjmay
Re: mk8 engines
Postby wojciech » Mon Aug 21, 2017 11:25 am
loot wrote: til 2016 then introduced dw psa 2.0 (diesel) engine euro 6 with power output 130ps and 170ps.
It wrote really somebody... green :mrgreen:
wojciech
Re: mk8 engines
Postby man le-mans » Wed Sep 06, 2017 9:19 pm
Willjmay wrote:The new 2.0l engine is a brand new euro 6 engine developed in Dagenham. It's code name was Panther. It is not a PSA engine.
Is that right, so turbos injectors and so on are exactly the same
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Re: mk8 engines
Postby huns » Sat Sep 09, 2017 2:01 pm
I have the strongest 2.2L variant (no adblue), and it's struggling to keep up with even smaller hills if I have ~1.2T loaded on it. It's only an LWB variant too, not a Jumbo. Don't get me wrong, if you don't put too much load on it, it flies. Then again, the MK7 with the better engines also flew.
So I wonder what the 2.0L engine is capable. Looked at reviews, they all cry about that the new one has zero amount of power. So yeah, do research and test drive one before purchase.
PS.: I don't even understand. Mercedes has V6. Renault has 2.3L. Hyundai has 2.4L. Why the HELL is Ford using such wimpy weak engines? It's mind boggling. Ford has the looks, the comfort, the ergonomics, the tech. And then they ruin it all with the engine. There is some serious shakeup needed in the leadership department at Ford.
- Transit MK8 LWB 2.2D 155 bhp - Trend - Cam: Viofo A119 cfw
- Tourneo Connect LWB 1.5D 120bhp - Titanium - Cam: Lukas WK-7950 Dual
- Mondeo MK4 2.2D 235bhp stage1 - Titanium - Cam: Viofo A119 cfw | 70mai Dash Cam Pro
huns
Re: mk8 engines
Postby Willjmay » Sat Sep 16, 2017 12:57 pm
The 2.0l euro 6 is 100% identicle in every model. As is the 2.2 engine in the euro 5 models. it's a just different map.
I think the 2.0 euro engine is pretty good (130bhp in a motorhome) and pulls well enough for what I want to do.
yep, 3.5 tons with the aerodynamics of a barn door, it struggles up long hills.
Ford claim to use the same eco-boost technology as their small capacity petrol engines in this diesel engine.
There are some 'teething problems' - oil change intervals and problem injectors in the early engines.
Remaps are starting to appear, Martyn at Pendle Performance has remapped the Ford euro 6 to a little over 200 bhp and 400 nm of torque.
The new PSA euro 6 van engine is also 2.0l and boasts similar bhp outputs to the Ford Panther engine and also uses adblue technology.
Fiat use a double exhaust recirculation (EGR) system rather than an adblue solution.
It's all driven by EU regulations, let's see how they all fare in the long term.
Given a choice, I would prefer to cruise around in a lazy 3 litre diesel and hardly ever have to change out of top gear.
I would also prefer no cat, no EGR and definitely no DPF, it's not going to happen though in a modern van though.
Willjmay
Re: mk8 engines
Postby karl » Sat Sep 16, 2017 3:53 pm
And then use a 3.2 5pot in the new ranger :lol:
Euro 6 adblue the engine looks like the euro 5 one :roll:
karl
Tranny Lover!!!
Re: mk8 engines
Postby 4door4 » Sun Oct 08, 2017 4:38 am
That's impressive if they all use the same turbo. Usually a turbo that can do 170ps on small engine has some trade off in throttle response and lag, then the lower power engine gets a smaller and quicker spooling unit. Do the new fancy turbos do all of this without even going to a twin-turbo arrangement?
4door4
Re: mk8 engines
Postby psv-hgv-flt » Sun Oct 08, 2017 10:04 pm
huns wrote:I have the strongest 2.2L variant (no adblue), and it's struggling to keep up with even smaller hills if I have ~1.2T loaded on it. It's only an LWB variant too, not a Jumbo. Don't get me wrong, if you don't put too much load on it, it flies. Then again, the MK7 with the better engines also flew.
yea,,no good for towing.,,,,,and there is problems with it already.
psv-hgv-flt
Re: mk8 engines
Postby yzr750 » Mon Oct 09, 2017 1:57 am
Mine's fine for towing..........
yzr750
Re: mk8 engines
Postby RichH » Thu Nov 09, 2017 9:33 pm
Would there be any way to get the U.S. spec eco boost engine in a new transit?
They really seem to motor!
0-60 in no time.
http://www.rhdoorsandshutters.co.uk
Automatic door and roller shutter specialists.
RichH
Re: mk8 engines
Postby loot » Fri Nov 10, 2017 12:20 am
1.0l fiesta 120ps :lol:
I don't like the idea of that much power at the piston, reeks of overheating pistons to me.
Although I'm sure the engine makes know what they're doing :-)
Ids map here
loot
Re: mk8 engines
Postby RichH » Sat Nov 11, 2017 9:10 am
I really want a 3.5 ecoboost.
Do you think Ford would do it as a special order?
RichH
