KevofCov wrote:Just my ten pen'th worth - don't do it.
DAB is unreliable - always dropping signal or no signal at all. The hype is wrong its a poor system.......
Altransit wrote:KevofCov wrote:Just my ten pen'th worth - don't do it.
I used to think the same, I fitted a DAB radio in my old Focus a few years back, it was hopeless, and I removed it and sold it on. But, the factory fitted DAB in my Mk3 Focus works well, so much so, I was thinking about getting a DAB radio to go in the Mk7
bambi mk 1 wrote:Navan spells Navan spelt backwards but DAB dosent spell DAB
Altransit wrote:bambi mk 1 wrote:Navan spells Navan spelt backwards but DAB dosent spell DAB
That's quite true, but you've lost me as to what you're on about
clarkey1 wrote:KevofCov wrote:Just my ten pen'th worth - don't do it.
Do you just mean the standard system you get from ford is rubbish? I put an aftermarket radio in my mk7 with the screen mounted aerial and it was spot on in 99% of the areas I worked in.
Mike wrote:
No, he means that DAB is sh*t in his area. And to be fair it is very dependent on where you want to listen, but if you lose DAB signal the (Ford) radio switches to FM. It’s getting better by the day.
