Transit 470 L4 H3 van
Postby bluecraig0776 » Wed Aug 15, 2018 8:34 pm
Does anyone know if an operators licence is needed for the 470?
bluecraig0776
Re: Transit 470 L4 H3 van
Postby bluecraig0776 » Wed Aug 15, 2018 8:52 pm
Found out it does.
bluecraig0776
Postby Jay2018 » Fri Aug 24, 2018 1:35 am
I thought an operators license is for when you want to run a fleet of work vans or something along those lines?
2012 MK7 Transit Trend 125 T350 6 SPD FWD MWB MR (Frozen White) :D
2010 MK7 Transit Jumbo 100 - SOLD :(
Galant VR4 8th Gen Type S(TT), 300ZX(TT) + S14A(T), Supra MK3(T), Golf MK4 1.8(T), GS300 & Civic EG9 VTI (ALL SOLD)
Jay2018
Will a 7.5 license not cover one to drive a 470?
Jay2018
Postby Altransit » Fri Aug 24, 2018 11:30 am
Jay2018 wrote:Will a 7.5 license not cover one to drive a 470?
You don't necessarily need a 7.5 tonne licence to drive a van over 3500kg, I can drive up to 7.5 tonne on my car license, but if you drive a van over 3.5T commercially, then you need an operators license, which brings all sorts of complications, and expense, to a small business.
This is precisely why there are so many overloaded 3.5T vans, and trucks, out there on the road.
Postby hughesyn » Fri Aug 24, 2018 4:40 pm
True.
Plus you need a tacho.
Same for a trailer, more trouble than it's worth.
We've got a drop side mk8 and the payload is only about 1 ton. Shocking really.
We considered a trailer, but that would need a tacho and operators license.
If you are FORS registered, >3.5t is even more of a pain.
2023 Mk8 DCIV 170 auto L3H2
hughesyn
Postby Altransit » Fri Aug 24, 2018 10:45 pm
Realistically, the 3.5T limit should now be raised to at least 3.9-4.0 Tonnes GVW. Most modern larger panel vans are well able to carry this already, with better engines and braking systems than the older vans which were common when the law was brought in.
I do think that they should be speed restricted at that weight though :mrgreen:
Postby dumper » Sat Aug 25, 2018 8:54 am
I’ve read somewhere that for electric vans they are going to increase the gvw to compensate for the weight of the batteries and also the categories of drivers who can drive then on a car licence
Postby bambi mk 1 » Sun Aug 26, 2018 11:55 am
dumper wrote:I’ve read somewhere that for electric vans they are going to increase the gvw to compensate for the weight of the batteries and also the categories of drivers who can drive then on a car licence
You have read right :)
bambi mk 1
Postby dumper » Sun Aug 26, 2018 12:52 pm
Cheers bambi
Postby Jay2018 » Tue Aug 28, 2018 7:32 pm
Learning learning...
Jay2018
Postby cutealpaca » Mon Jan 13, 2020 7:06 pm
I came here with the same question as the OP. Just to confirm, does this mean I can buy and drive a Ford Transit 470 on my standard car licence (Cat B) for personal use, even if it's loaded beyond 3.5T? I want to convert a van into a camper, but the payload of ~1100 for the 350 is too low for me.
cutealpaca
