Transit mk8 2014 van, I have fitted the leather steering wheel with cruise control functions and programmed the computer to initiate the function but it tells me I need the cruise control module which my local Ford dealer cannot locate in their parts book and the auto electrician says he has never see or heard of one, any help would be much appreciated,regards
If it's the same setup as a Mk7, then there's no separate module for cruise control, but you do need to have a high spec Body Control Module, which can be programmed to initiate cruise. Unless your van already has lots of "toys" fitted as standard, you may well not have the correct BCM
1994 Mk4 SWB 115 Minibus 70ps Di (R.I.P.) 1997 Mk5 SWB 115 Minibus 70ps Di (Gone, but not forgotten!) 2004 Mk6 SWB T280 Medium Roof 85PS 2.0 TDDi - Vantunered (Also gone) 2008 Mk7 SWB T280 Medium Roof 85PS 2.2 TDCi - Also Vantunered
Also it might not be as simple, you might need to swap more modules ie steering module, bcm maybe more. The modules all have their own vin which I don't know if they can be reprogrammed or used and configured.
Need more info.
56 350 2.2 130ps mk7 with 2 side doors 65 290 2.2 125ps custom with 2 side doors 07 350 170ps Ids v86 licence + v86.04 update + xprog here Ids map here
