Broke down Help!
Broke down Help!
Postby poolie » Wed Oct 17, 2018 2:20 pm
Hi all
I have a 125 ps mk8 tipper with 107k on clock.
As I was driving I noticed a burning smell van started to run roughly, I've pulled over oil is leaking from filler cap. There is no smoke from exhaust. I then ran another 2 miles and dash said service engine now so I pulled over and turned it off. Waiting for green flag. Engine isn't knocking but sound like it's running roughly.
Any suggestions please? I pray it's not a new engine...
poolie
Re: Broke down Help!
Postby poolie » Wed Oct 17, 2018 7:15 pm
Anyone? Green flag put it on a diagnostic tool, one fault code came up turbo super charger underboost.
There was no smoke or nothing, engine still sounds ok no knocking etc and still drives. Engine seems to shake when driving and ticking over.
poolie
Postby dumper » Wed Oct 17, 2018 8:44 pm
Have a look at the turbo remove the intake pipe see if it’s got excessive play and check fo oil in intercooler pipe work their will be some m8
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby poolie » Fri Oct 19, 2018 3:24 pm
Garage reckons injector seals? I'm not so sure at all. Would injector seals cause oil to come from filler cap?
poolie
Postby V184 » Fri Oct 19, 2018 4:31 pm
poolie wrote:Garage reckons injector seals? I'm not so sure at all. Would injector seals cause oil to come from filler cap?
wouldnt have thought so :?
V184
Postby andz327 » Mon Oct 22, 2018 2:37 am
If it was a mk7 then aye injector seal can cause it, but not sure if mk8 has similar set up or not
Sent from my LG-H870 using Tapatalk
andz327
