Pad wear sensors rwd 350
Postby cornishpasty » Fri Nov 16, 2018 2:49 pm
Any one any idea which way the circuit runs and where start and finish are ?
Fitted sensors on all pads, rears have been joined for along time but now getting brake warning service now.
Just put front pads and new sensors but warning not going.
Thinking van side break but not sure where wires go to test.
cornishpasty
Re: Pad wear sensors rwd 350
Postby cornishpasty » Thu Nov 22, 2018 9:27 pm
So no one has had the misfortune to suss out which way the cables run?
cornishpasty
Postby p2thed » Sat Nov 24, 2018 8:03 pm
Rear runs across axle, up to multiplug then along main loom under fuel tank. Joins at a 30ish pin plug behind nsf headlight then goes to both front wheels then loops down to abs module.
p2thed
Postby loot » Tue Dec 04, 2018 2:07 pm
Guys there's a search function.
Covered many times.
Also don't confuse abs sensor system with brake pad wear system.
Brake pad wear is just a single wire loop to ground, if it breaks it open circuits and tells the speedo to illuminate the lamp. Pin 15 and pin 18 at the speedo connector can be bridged to permanently turn it off. Otherwise you need to find the breaks in the wiring.
Ids map here
loot
