Space above cab?
Space above cab?
Postby glasgowdan » Fri Nov 23, 2018 9:30 pm
Has anyone got any information on using the space above the cabin in a MK8 transit? I'm considering buying one and have a set of 10ft ladders I strap to the ceiling that poke through into that space in my mk7. The MK8 have a panel screwed over this void and a peek inside the edge seems to suggest it's just soft padding, which shouldn't be a problem as the ladders will likely rest on the edge of the bulkhead.
glasgowdan
Re: Space above cab?
Postby dumper » Sat Nov 24, 2018 7:03 am
My bus doesn’t have the void as it has full hight roof lineing but on the vans they are similar to the mk7 but smaller as the cab roof panel is higher so you’re ladders would rest on the top when I looked at vans for my camper conversion I only looked at hight tops their was no padding inside the void so you’d have to protect the inside to stop damage to the front of the van some had a door above the cab some I looked at didn’t
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby man le-mans » Sat Nov 24, 2018 9:36 am
I tried to take mine off as I needed to get 3 meters of pipe in my van, but it’s part of frame that holds the head lining so don’t think you can
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Postby dumper » Sat Nov 24, 2018 11:42 am
I think he was asking if he was able to rest front of ladders on it I think he should be able to
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby dumper » Sat Nov 24, 2018 1:12 pm
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby glasgowdan » Sat Nov 24, 2018 7:49 pm
man le-mans wrote:I tried to take mine off as I needed to get 3 meters of pipe in my van, but it’s part of frame that holds the head lining so don’t think you can
That'd be a bit of a pig. I am sure it could even be cut? I just need a slot about 18" wide and 3" high for this end of the tripod ladder
glasgowdan
Postby man le-mans » Sun Nov 25, 2018 10:42 am
I took all the bolts out as I never wanted to cut mine, but it seems to go into the head lining. I ended up making frame work and putting the pipe on the floor where the bulk head goes in which works much better
man le-mans
Postby hectors-tranny » Sun Nov 25, 2018 4:46 pm
Mine is a steel shelf. Very strong. But note the area is smaller than on Mk 7 as the cab ceiling is higher.
In the pic it is the black layer just above the yellow foam padding blocks.
Mine is a UK 2016 Trend L3H3. Not sure if that makes a difference?
hectors-tranny
