Mk8 Adaptive cruise control
Postby Traco » Mon Jan 07, 2019 11:31 am
Hi - just wondering if anyone has an issue with a Mk8 and the adaptive cruise control and if so could you share? If not here a PM would be appreciated.
Its 2016, highly spec'd trend. L350 trend with 155bhp. Its minded like a small child and was spec'd and purchased new. The mileage is low on it but need to check, low to mid 30k kms at present.
2016 L3 H3 Trend 155bhp
Traco
Re: Mk8 Adaptive cruise control
Postby Altransit » Mon Jan 07, 2019 3:30 pm
What issues are you having :?:
Postby Traco » Mon Jan 07, 2019 4:13 pm
It will emergency brake and has done so in good conditions for no reason and the brakes will not release until the brake pedal is manually pressed all the way down. Only then does the system reset and release the brakes.
Traco
Postby Altransit » Mon Jan 07, 2019 6:51 pm
I can't say that I've heard of that problem before, but it may be worth checking that the radar unit is in its correct position, and not obscured in any way :idea:
Postby Traco » Tue Jan 08, 2019 11:18 am
I will have a look. It’s going back in again but I think it’s too random for that I suspect.
Traco
Postby Traco » Thu Jan 10, 2019 7:27 pm
I had a look and can’t see anything that looks like a sensor (found pics of what it’s like on IS cars) but doesn’t seem to be fitted to mine.
There are two sensors up behind the rear view mirror on the windscreen. One sort of looks a bit like a camera but don’t think it is. It’s rectangular in shape the other is circular with several dots on the glass.
Traco
Postby dumper » Thu Jan 10, 2019 8:14 pm
One possiblely auto wipers and one for auto headlights that’s what is on my older van
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Altransit » Thu Jan 10, 2019 8:23 pm
You may have a forward facing camera behind the mirror if you have speed sign recognition, or auto dipping headlights, but I don't think the cruise uses it at all. The other sensor may be for auto wipers :?:
What you will have with 'ACC' is a RADAR unit, mounted at the front, low down, behind one of the grilles. My thinking is that if this unit is obscured, or moved position, it won't be able to "see" properly, and may be giving false data :idea:
Postby Traco » Fri Jan 11, 2019 11:34 am
Will have a look again. Any pics of where it should be located. I couldn’t see it behind the main grill so maybe it’s down in the bumper area
Traco
Postby hughesyn » Fri Jan 11, 2019 2:39 pm
The Bemm manual metions getting vertical alignment of the radar checked by a dealer if the vehicle weight or geometry is significantly altered.
Here's the location of the radar:
2023 Mk8 DCIV 170 auto L3H2
hughesyn
Postby Traco » Fri Jan 11, 2019 8:06 pm
That on mine. All the sensors are behind amtye plastic panel that’s part of the grill. Everything looks tight as afar as I can make out but very hard to tell without taking the grill off. It’s back to a Ford dealer on Monday so let’s see what they say.
Traco
Postby Traco » Mon Jan 28, 2019 3:16 pm
Well it’s back from the dealer so we will wait and see. Radar module was checked and recalibrated and theee was a software update. Apart from that nothing else to report. Hopefully that’s it sorted and we can get some confidence back in the system.
Traco
Postby Altransit » Mon Jan 28, 2019 8:08 pm
Fingers crossed 8)
Keep us posted please :)
