Hi. Back to you guys after a few bad years in a sprinter. Lesson learnt.
I’m trying to find an ignition wiring diagram for a mk8 transit. Lots are going missing and I’m in need of getting a tracker attached pretty quickly.
Cheers.
loot wrote:Can't you just buy a voltage sensing relay? they turn on at 14+v
loot wrote:Looks like male space terminals will push in then heat shrink it?
wvc wrote:loot wrote:Looks like male space terminals will push in then heat shrink it?
Did exactly this. Thanks for the idea!
loot wrote:Result
