Job done. Piece of cake. Clear the brakes out of the way and its just the 5 T50 torx bolts and its off. No suprises.
Only prob when the bolts are out was getting over the corrosion holding the bearing housing tight into the sus leg. I found that the way to do it is put the wheel back on but backwards (for more leverage) and lower the van down using your trolley jack. The weight of the van will pop the bearing housing out but it happens suddenly. Use plenty of axle stands to catch the van or you may die.
Ford wanted £250 for the bearing but I used these;
https://www.ebay.co.uk/itm/FORD-TRANSIT ... 2749.l2649A fifth of the price and all seemed good when fitted
