Hi does anyone know how to remove a worn bump stop ? Ive bought a replacement but cant work out how to remove the old one and ford wont tell me how to do but will fit at there normal rates!!
Many Thanks in advance
cornishpasty wrote:You need to jack up van to drop axle as far as possible and use socket and short extension up the centre of bump stop to remove bolt.
Can not remember the size but simple enough when you suss the right size socket.
