Hi
I have a 2014 Mk8 transit 2.2 77000 miles
It went into limp mode as the eml came on
The codes read dpf blocked and glow plug 2 faulty
I had the dpf chemically cleaned and all 4 glow plugs replaced
All setting reset so happy days
Then5 days later after only 100 miles the eml on again and back into limp mode
Took back to garage and dpf reading was 170 which they said impossible after the clean
So they reset again
1 day later eml back in and in limp mode ..
They then told me it could be needing a software update form Ford on ecu
That’s £100 so before I go ahead has anyone else had this or a similar problem ???
