Well what a welcome to the forum!
First comment telling me I've posted in the wrong section
, and the second questioning my judgment on what model I have
None the less, thank you for your warm welcome and reply to my first query.
For any one else having this issue i thought i would follow up what happened and how I've cured the issue.
First symptom was that I had a system check message on the dash that said "Parking Aid Service Req'd" on seeing this message i took it to my local ford dealer and they plugged there computer in. They told me that it was the loud buzzer that comes on constantly when you re too close to something, but then also said it could have been a wiring issue ect ect ect. I went away and thought i would investigate myself, purchased a new buzzer off the internet for £12 and thought i would start there. Locating the buzzer was slightly tricky, i ended up using a friends van to listen to the noise to locate their buzzer, to then find it on my own.
The buzzer is located above the cabin lights above the drivers seat (center on the van, almost above the headrests.) i ended up taking the lights out then popping my hand up and fishing the buzzer out. Unfortunately the new one came with the wrong connector on so i did have to do some cutting and soldering so the job wasn't completely easy/problem free
Hope this help's someone in the future
NewBoy
