polker8 wrote: Is he head gasket a common problem?.
polker8 wrote:Yes that sounds kind of like mine, it will only overheat if the engine is worked, ie, it will run round all day so long as i dont go above 5o, over that and it will happen. Is it a bad job to get the head off?, Does it have a belt or chain? Probably going to have to sort it out soon
