by loot » Wed Mar 25, 2020 4:49 pm
99% I'd say that you'll want new injectors unless you are 100% that it wasn't fuel related that blew the engine. But at the last you should get them checked.
You should still clear the learned values for fuel etc.
It'll be euro 5 so there's not really much programming to be done, if you do use the injectors again you can fit them in the same number cylinder that you removed them from so then you won't need to program them in.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
