Hi.I have had my 2.2 rwd 2014 plugged in and this comes up
c004a-13 brake lining wear sensor
c1d00-11 park brake apply switch
c004a-13-0a brake lining wear sensor
Have put new pads in rear and wires ok. Checked connection above rear axle.All fine. Front n/s has had wire sensor cut. I joined it together before it was plugged in and then cut it during plug in to see if it was that. Redone plug in test. Even unplugged o/s front thinking if I mimicked n/s to see what happened. Redone plug in test.All the same. Can I completley by pass the brake wear sensing system?
Any help appreciated.
