head bolt torque settings
Postby polker8 » Thu Jun 25, 2020 10:20 pm
Hello, would anyone know the correct torque setting for the head bolts on a 2.0 eco blue engine? Also the camshaft carrier and injectors?What a job to get this engine apart!,
polker8
Re: head bolt torque settings
Postby p2thed » Mon Jun 29, 2020 5:31 am
Head bolts are.
Stage 1 20nm
Stage 2 40nm
Stage 3 90 degrees
Stage 4 90 degrees again
Stage 5 90 degrees a final time.
p2thed
Postby polker8 » Tue Jun 30, 2020 8:31 pm
Thank you, That might explain why I could not get them undone, the ribe bit kept slipping out as they are such a shallow head, I resorted to drilling the heads off to get them out, might have to try harder putting it back together again,, plus i need a new set of injectors! good old ford
polker8
Postby Oddball1919 » Tue May 18, 2021 12:51 pm
Any chance you can remember what size RIBE bit i need for these head bolts? Taking one apart later in the week so may need to get the correct socket.
Oddball1919
Postby p2thed » Tue May 18, 2021 6:45 pm
60 torx plus
p2thed
Postby Altransit » Thu May 27, 2021 4:24 pm
p2thed wrote:60 torx plus
Is that why the Ribe bit wasn't fitting properly :?:
Postby p2thed » Thu May 27, 2021 6:33 pm
Yeah it will be one of these,just an fyi. I have had to weld a big nut to these before and they can be b :evil: rd tight
p2thed
