Airthies wrote:Have you checked the fuses?
Manuals here if you don't have one
https://www.ford.co.uk/owner/my-vehicle ... our-manual
Altransit wrote:In the Mk7, the receiver is under the headlining, fixed to the roof, near to the front cab courtesy light. It may be in a similar position in the Mk8, it may be worth a look
Do you have two batteries under the seat? Have both of them checked
austieman wrote:Hi all I thought I’d give a quick update.
I’ve been faffing around trying to get to the receiver from both the cab and over the top in the cargo space, but to no avail.
It seems to be tucked in the tiniest gap between the edge of the windscreen and the overhead cargo shelf which can’t be more than 6 inches across and I can’t even see it let alone get my fingers to it.
Either way I have accepted the fact that I’m going to have to take it to take it to ford to be sorted. I happened to be passing one recently and dropped in to see if they could potentially sort it on the spot but they just reconfirmed what I already knew which is that the key is definitely emitting a signal, and it would need a more comprehensive assessment to understand what the issue is. They said something about potentially recoding it or having to look at the receiver.
Thanks to those that have replied, I’ll post an update following the repair for everyone’s benefit. Maybe it can help someone in the future.
Cheers
Stuck69 wrote:Hi I’m interested to know if you found the receiver because I have the same problem both keys have been checked and the central locking works fine on the buttons on the door card and locks fine from the drivers door but nothing on the remote.
