by roperman » Sat Aug 22, 2020 6:00 pm
Brake fluid isn't/hasn't been low in my ownership.
Its definitely the fluid low warning as well, and not the pad low warning.
It only seems to have started since its been stood and the battery has gone flat.
I plugged it in to my delphi scanner and managed to clear one of the faults off, it was related to low voltage in abs unit.
If anyone knows where i can get a v95 or v96 download for IDS let me know as I'd like to try IDS on it.
I've had my multimeter on the wires to the resevoir sensor, one seems to be permanantly grounded, and the other seems to pull to ground when the ignition comes on. Not sure if this is normal but i'm going to investigate the wiring/connectors later.
Danny
