KevofCov wrote:I believe the van is able to analyse its own oil and flag up when it believes that there is an issue.
KevofCov wrote:Ask any mechanic – 30,000 miles is way way too long for an engine oil change. It’s criminal. Ford doesn’t care – they made the sale.
Change it every 10,000miles gents......
hughesyn wrote:Changing the oil more frequently won't make the vehicle last longer, so what's the point
Sam123 wrote:hughesyn wrote:Changing the oil more frequently won't make the vehicle last longer, so what's the point
I'm not sure I agree with that. I always find working on poorly serviced cars a nightmare, anything exposed to oil vapour gets gunked up with sticky oil deposit, and it makes fault-finding 10x more difficult. And that alone just doesn't happen with frequent oil changes and other servicing. That's particularly an issue with modern engines with all sorts of wizadry that can get gummed up, e.g. MAF, MAP, EGR/turbo VNT.
Even needing 10l of oil, a good quality oil and filter change costs less than £50, i.e. not much more than half tank of fuel. It seems a no-brainer to me to change the oil frequently. In my view 10k miles is the absolute upper limit for any engine oil.
I agree that with modern cars engine wear itself is rarely going to be the cause of death, but dirty engine oil causes all sorts of other issues.
dumper wrote:Sam123 wrote:hughesyn wrote:Changing the oil more frequently won't make the vehicle last longer, so what's the point
I’m with you Sam it’s more important with modern engines with a dpf it’s a cheap way to keep it happy
