Hi All
My 2014 transit 350 has developed a strange electrical fault
Sometimes the Van wont start and the service engine warning is flashing with a beeper
When the van does start the warning lights are off for a few minutes but then they all come back on , ABS , Airbag , traction control , ECU light
Once these lights come on if I turned the Van off it will not restart
Checked the fault codes and the ones below were present
P1607
U0121
U0100
U0159
After these were cleared the van started but after a few minutes the lights came back on and the codes below were stored
U0001
U0140
U0126
U0151
When all the service engine warning is flashing there is no connection to the ECU through the fault code reader
I checked under the bonnet and the ECU area is a mess, very corroded, its been getting a lot of water from the drain from under the windscreen
