Timing belt recall
Timing belt recall
Postby tt225 » Fri Jan 29, 2021 12:23 pm
I've just been into Ford this morning to have the overrun fuse recall done on my 2017 2.0 Eco Blue and was informed that another recall has just been announced relating to the timing belt and its a 5 to 6 hour job. I've not received the letter from Ford yet but the parts are on back order from Germany and my local dealers will contact me when they're in - has anyone else heard about this?
Sent from my SM-G780F using Tapatalk
tt225
Re: Timing belt recall
Postby Smiles_Nottingham » Fri Jan 29, 2021 12:24 pm
just booked for the overrun recall also and told there are three others including the timing belt recall
Smiles_Nottingham
Postby tt225 » Fri Jan 29, 2021 12:26 pm
Smiles_Nottingham wrote:just booked for the overrun recall also and told there are three others including the timing belt recall
What are the others? I know there was an injector recall on some engines and although all injectors were replaced on a 2017 custom.i had, I never received the letter
tt225
Postby man le-mans » Fri Jan 29, 2021 6:47 pm
They must’ve had a lot of failures for timing belts. They probably going to put a reinforced one in.
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Postby austieman » Fri Jan 29, 2021 7:53 pm
tt225 wrote:I've just been into Ford this morning to have the overrun fuse recall done on my 2017 2.0 Eco Blue and was informed that another recall has just been announced relating to the timing belt and its a 5 to 6 hour job. I've not received the letter from Ford yet but the parts are on back order from Germany and my local dealers will contact me when they're in - has anyone else heard about this?
Just checked Etis, and mine is on the recall list as well, but it says for a "timing belt inspection". Did they say specifically they were going to do? hoping its more than just an inspection and actually a replacement.
Mk8 L3H3 2.0L
austieman
Postby p2thed » Sat Jan 30, 2021 1:02 am
Maybe of some use
p2thed
Postby p2thed » Sat Jan 30, 2021 1:03 am
2
p2thed
Postby tt225 » Sat Jan 30, 2021 9:08 am
From what they said it was going to be a 5 or 6 hour job so would have thought they'd replace the belt if it takes that long
tt225
Postby austieman » Sun Jan 31, 2021 11:01 pm
p2thed wrote:2
Thanks p2thed, So it sounds like they’ll do an inspection to determine the state of the belt before deciding to replace it or not. Will check mine myself in the morning if it is just a case of looking into the oil filler cap.
Pretty shoddy really, this is the third recall I’ll have had on my van (missed out on the injector recall), Ive also had a fuel pressure sensor failure leading to a misfiring engine. I’m starting to think they should be buying all these vans back...
Mk8 L3H3 2.0L
austieman
Postby Chrisp74 » Mon Feb 01, 2021 2:27 pm
Mental note to self make belt inspection part of my routine service.
Who new. Cambelts in oil :roll:
Cheers for the heads up!
Chrisp74
Postby p2thed » Wed Feb 03, 2021 5:58 pm
Just an update, all timing belt recalls have been cancelled until May due to parts issues
p2thed
Postby tt225 » Wed Feb 03, 2021 6:14 pm
Nottingham Sandicliffe did say that the parts were on back order but didn't think it was going to be the Summer almost.
I Blame Coronavirus and Brexit
tt225
Postby man le-mans » Wed Feb 03, 2021 7:14 pm
Fords replied to a mates email because his trend don’t have folding Mirrors, and their reply was they was short on parts at that time of production. I wonder what they would do if they run out of steering wheels, leave them off
man le-mans
Postby Willber37 » Wed Feb 03, 2021 9:52 pm
I had the fuse recall done September last year..
Just checked my vehicle for the timing belt but says nothing due on the Ford Etis system?? Mines a 66' plate.. so what has changed if anything in 6 months on the 2.0 Ecoblue? Surely I have the same engine?
Willber37
Postby cornishpasty » Thu Feb 04, 2021 8:12 am
We had belt break on 3.5 year old van and Ford have fitted engine under warranty even though out of it.
Van less than 100000 miles.
They are surely admitting a problem.
cornishpasty
