Anyone with a Mk8 will presumably have the issue of the scuttle leaking rain water into the engine-bay at both sides. It seems a really poor design, the driver's side leaks onto the airbox and the passengers side leaks onto the ECU and chassis leg etc.
The below shows where it leaks from on both sides:
There are some aftermarket trim pieces that Ford produced to counter this issue. My 2015 van already had the driver's side piece installed when I bought it:
But it didn't have the passenger side piece. So rain pissed and and the ECU was constantly soaking and the chassis leg held water. I knew there was a Ford piece, but just couldn't find a part no. So I made the below to catch the water:
Which worked, but was a bit ugly.
The only reason I made my own was because I couldn't find the proper Ford part. But the other day by chance I happened to find it on the parts diagram. Its hidden away in with the HVAC ducting:
It's part 02408 on the diagram.
RH (driver's side is Ford part no 1927680 - there's a few on ebay for around the £10 mark -
https://www.ebay.co.uk/itm/Genuine-Ford ... SwV7pfNjtkLH (passenger's side is Ford part no 1936723 - £14 on ebay -
https://www.ebay.co.uk/itm/Genuine-Ford ... Swq4tfaeG~So I bought and fitted it, and got rid of my bodge job. To fit you just remove the original drain pipe and it clips on. And problem solved, much smarter:
Thought this may be of interest to others with MK8s.
