JamesHow wrote:Are you converting it?
Yours seems a different spec to mine without the plastics down the side.
Nice seats. I have a spare BMW 5 series seat would that fit?!
Failing that some Volvo seats.... Always had Volvo's so would like some Volvo in my van. Perhaps if the engine goes I can put in a D5!!!
Cheers James
Cheers James
Nickmcd wrote:Ford galaxy seats will fit. Some are swivel seats. They turn about 90deg so you need to remove the stop to allow them to turn 360 degrees. Currently converting a L3H3, bought a 2nd hand drivers seat base, fits where the double came out from. Bought 4 pieces of 8mm thick 100mm wide steel bars cut to length of the seat base, fitted to seat bases using original seat bolts and bolted the galaxy seats to the bars. No issues, no need to lower the handbrake, just release when turning the seat then re-apply.
Single passenger seats for the transit are huge money!
Winbro77 wrote:The standard transit seats don't have airbags. These do but I haven't plugged them in so they aren't active.
