Hello all. Need to disconnect battery to weld a couple of bits. Can anyone tell me if I will need a radio code or anything else to be aware of when disconnecting battery?
Many thanks
cornishpasty wrote:You can fit another radio without coding so disconnecting battery should be fine
dumper wrote:Yes will be ok when I was building my van had them off many time and after fitting new batteries no need to enter a code.
