Hi All, after a little help.
I have a 68 plate luton 2.0 fed, in the last six months I have had the following.
Injector corrosion all four replaced under warranty, then 6 weeks later engine failed replaced under warranty, then error saying fuel filter blocked service due then another two weeks later hill assist light on, add blue malfunction and dpf overload all at the same time, sent van back to main dealer, found that the pcm and engine wiring loom has corrosion. Ford refusing the warranty as the van has just gone over 100,000 mile but still under 3 years.
After looking at the pcm / loom plug the green seal in the plug is broken and this has let the water in. Ford dealer said that this plug was not touched previously and this must have happened at build stage...so my question is..could the long term leaking caused the initial problems that have incountered????? Thanks for reading
