Front brake pads
Front brake pads
Postby man le-mans » Fri Sep 10, 2021 2:07 pm
How easy are the front pads to change on 68 plate 350. I’ve done lots on older cars year’s ago but as said was years ago. I’ve heard that some cars vans need special tool to twist the Brake caliper to get the new pads in.
I seen a few videos on YouTube but they have all been on older mk8 2.2 engine and just wondering if anything has changed on the newer vans.
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Re: Front brake pads
Postby Max4music » Fri Sep 10, 2021 3:40 pm
Ive done the older 2.2 mk8. I recall using the twisty tool, but very easy job. I doubt it will be any different on the 2.0L version. These things are made for high mileage and regular changes. Cheap brake tools are available on ebay etc. Well worth the investment.
Max4music
Postby karl » Fri Sep 10, 2021 9:58 pm
no special tools to do the front just a big screwdriver to push piston back before you remove the old pads
the backs need a rewind tool and the left side passenger is left hand thread and the drivers side rear is right had thread
karl
Tranny Lover!!!
Postby man le-mans » Sat Sep 11, 2021 8:44 am
Thank you for your advice
man le-mans
Postby Altransit » Sat Sep 11, 2021 12:13 pm
Postby man le-mans » Sat Sep 11, 2021 4:40 pm
Altransit wrote:Is this any help :?:
viewtopic.php?f=18&t=195998
Thanks al and yes it all helps.
Looks not much different from how they used to be years ago so hopefully should be straight forward job
man le-mans
Postby mcbutler » Sat Sep 11, 2021 9:37 pm
Take the cap off your brake fluid reservoir before you force the pistons back. IOf the fluid has been topped up as the pads have worn it will be ejected from the reservoir, and we all know that brake fluid is also a very effective paint stripper
2014 Mk 8 Jumbo 350 2.2 RWD single rear wheels
mcbutler
Postby KevofCov » Mon Sep 13, 2021 7:21 pm
Yes straight forward - no suprises
KevofCov
Postby man le-mans » Wed Sep 15, 2021 4:55 pm
Thanks everyone for the advice it’s much appreciated and was all straight forward like said.
The only problem I had was the front locking wheel nut was overtightened which ended up stripping the locking wheel nut key. So had to get a new one from Fords and then had to cut that one off, as it stripped the second key. I did undo the others in case that happened again tho. then I also replaced that one and the other locking wheel nuts with normal nuts so that it’s not a problem again.
Because the van is just 3 years old this month and been serviced at Fords I’m guessing the wheels have never been off as the pads are the first thing ever to be replaced.
Also surprised that the brake wear sensor is only on the left side and not both.
man le-mans
