Altransit wrote:In a Euro5 engine, increased oil level can be caused by diesel being dumped in the oil, from failed DPF regenerations
dieselhead123 wrote:Altransit wrote:In a Euro5 engine, increased oil level can be caused by diesel being dumped in the oil, from failed DPF regenerations
I've never quite understood this explanation
Are we saying that diesel is forced through the injector in the DPF, then 'climbs' up the exhaust downpipe, through the exhaust rotor of the turbo and in to the engine via the exhaust valves, all while the engine is running?
Another, more likely, explanation is that the high pressure pump shaft seal has failed, permitting diesel to enter the timing chain case.
Altransit wrote:because I'm not a diesel expert
Mike wrote:Do a search, there’s loads of info about it here. And don’t be drawn in by the ‘mechanic’
