oil level goes up
Re: oil level goes up
Postby Mike » Sat Oct 16, 2021 10:27 am
V184 wrote:If exhaust gas temperatures don’t reach a high enough level due to frequent short journeys at low speed the ECU can place the engine into regeneration mode. During regen mode the ECU will conduct post injection, this is the process of injecting extra diesel into the combustion chamber after the main injection cycle. Post injection helps to increase exhaust gas temperatures however much of the injected diesel is left unburnt and filters its way down to the oil sump resulting in oil level rise.
Very eloquent, I didn’t know you had it in you…
Mike
Wind up merchant!
Postby dieselhead123 » Wed Oct 20, 2021 4:30 pm
Are we saying Ford made a mistake with this process, given the potential engine damage that could occur?
Would previous failed re-gens not show up under diagnostic interrogation?
If so then pinpointing the cause of the rising oil level would be straight forward.
Given it is unlikely that Ford made such a huge mistake, the other possible causes should also be investigated.
Postby zeemeester » Wed Oct 20, 2021 4:37 pm
how can i get the engine out of " regeneration mode "
zeemeester
Postby dumper » Wed Oct 20, 2021 6:09 pm
It’s not just a Ford problem it happens on HGFs and PSVs and our other different manufacturers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Mike » Wed Oct 20, 2021 6:53 pm
You probably need to ask the person who wrote the post :wink:
Mike
Wind up merchant!
Postby V184 » Wed Oct 20, 2021 8:20 pm
dumper wrote:It’s not just a Ford problem it happens on HGFs and PSVs and our other different manufacturers
Had the same problem on a euro6 Vito :(
V184
Postby dumper » Wed Oct 20, 2021 9:37 pm
Porky fingers strike again should be HGVs
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
