p0045 code Turbo actuator
Postby KevofCov » Wed Oct 20, 2021 11:51 am
Van is a 2015 2.2l rwd duratorq
Getting an p0045 code and limp mode intermittantly (with traction control warning light). I believe that just the actuator can be purchased without the turbo. Is it a straight forward job to swop the actuator?
KevofCov
Re: p0045 code Turbo actuator
Postby Sam123 » Wed Oct 20, 2021 12:24 pm
You have to remove the turbo completely to do the actuator. You can't really just remove the actuator leaving the turbo in-situ, or at least when I did it it didn't look possible.
Removing the turbo isn't difficult so long as the nuts attaching it to the exhaust manifold come free. Be careful with these - work them back and forth a bit rather than just brute force. I did brute force with mine and snapped the manifold stud, and so had to replace the manifold, which was a right pain. If everything comes undone, its a fairly easy 2-hour (DIY) job to remove the turbo, no special tools from what I recall.
You can get Chinese-special replacement actuators, but not genuine Hella parts. If possible I'd try and find a NOS or low mileage used turbo and genuine actuator complete, rather than a Chinese actuator, which tend to be iffy quality. Also, the fault isn't necessarily with the actuator, it might genuinely be the turbo VNT vanes are gummed up, so complete replacement is obviously easier if you can fine one. I managed to find a genuine NOS Garrett turbo wuth genuine Hella actuator on ebay when I looked.
Sam123
Postby KevofCov » Wed Oct 20, 2021 8:21 pm
Cheers Sam.
I am going to check the connector plug first due to the Traction control light coming on when the code is generated. This make no sense and is simular I believe to the known 2.0L Panther (same age same van) actuator wire connector issue.
KevofCov
