sruggling with brakes
Postby karl » Tue Oct 26, 2021 12:49 am
on a 2015 mrk 8
ended up with this job from another garage who had changed the rear brake caliper and discs etc their diagnostics wouldnt connect to the abs etc etc
anyway i have the headache of the job now :roll:
so after going threw everything, my diagnostics wont communicate with the abs module either but will let me bleed etc brake lines
i have had all the wiring apart check for corrosion in the pins etc all fine
i have just changed the master cylinder and still carnt get a pedal at all
i have brake booster fault code and pcm and abs communication fault codes
am thinking the abs is knackered but before i go and get another
would like dome pointers before i do just incase i have missed something
karl
Tranny Lover!!!
Re: sruggling with brakes
Postby karl » Wed Oct 27, 2021 5:53 pm
sorted this
its was a faulty rear brand new brake caliper :lol:
karl
Tranny Lover!!!
Postby V184 » Wed Oct 27, 2021 10:53 pm
karl wrote:sorted this
So you changed the master cyl for no reason ?
V184
Postby karl » Tue Nov 02, 2021 10:31 pm
yes i did :shock:
karl
Tranny Lover!!!
Postby dumper » Wed Nov 03, 2021 8:22 am
It does happened you expect a new component to be ok even original parts from Ford had it many times over the years .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby MinorMatt » Thu Nov 11, 2021 4:41 pm
How does a dodgy caliper stop the diagnostics communicating? :shock:
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
