hello again,
transit 2.2 125 hp 2016 .
can somebody tell me the readings on the temp sensors 11 12 and 13 in the dpf ,its the green , blue and black cable.
my readings are :
outside temp is 6 celsius engine is cold and not running
sensor 11 blue 63,1c
sensor 12 green 63.1c
sensor 13 black 5.8 c
took te sensors out sensor 11 has 6.5 ohm
12 6.5 ohm
13 200 ohm
start the engine, temp goes up in sensor 13 until 63.1 and from that point they go up al three until 320 celsius.
do they have a minimum setting ??
thanks michael
