p2thed wrote:I have had issues on a few vans were after fitting after- market alternators for customersthey have caused issues. I now only fit Ford ones.If the alternator is installed and rated correctly for that van then it maybe the part itself. Do know why the original alternator was replaced.
Hi no other codes and yes the van died due to no power from alternator everything else touch wood is working as normal, i used forscan to try and clear codes but it either doesnt do it or fault recurs, and there are no lights on just when you accelerate Regards Annep2thed wrote:Is the abs light on ? The code will most likely be set due to improper shut down due to low or incorrect voltage. Am i right in saying that you had no issues other than a charging concern before the alternator was replaced?
Are any other codes present, have you checked all related abs fuses.
