by hughesyn » Fri Dec 17, 2021 1:23 pm
The crewvan has a solid bulkhead behind the rear seats, so unless you cut a hole in it, you can't slide something under the rear seats.
Ther is no 'front bulkhead', but there is a plastic cover on the back of the storage compartment under the dual passenger seat.
If you were to cut a hole in the bulkhead, then you would fit a 3m pipe in.
The non-crew SWB has 3044 loadspace at floor to bulkhead. So you'll have slightly more than that to the rear of the front passenger seat.
This is for a full fat Transit...
I doubt anyone has tried it because crewvan sales are tiny and most people woulnd't then cut a hole in the bulkhead.
2023 Mk8 DCIV 170 auto L3H2
