Blizz wrote:You can change the setting with FORSCan as the ECU already has the 170 program in.
Blizz wrote:Don't think the 105 and the 170 are the same, but that's true with the 130 and 170. You can change the setting with FORSCan as the ECU already has the 170 program in.
Cheers,
David
