New Van Leaking Scuttle
Postby dethleffs » Sun May 01, 2022 2:03 pm
Today I’ve opened the bonnet on my new 22 reg transit Camper to find the engine very wet and the soundproofing mouldy on the wheel arches. The bulkhead rain gutter under the windscreen is leaking where the passenger wiper spindle is and dripping on to the air filter housing also the area where it is supposed to drain into at the ends was blocked by two big (sopping wet) sponges in bags !
I recall I had a similar situation on my MK7 in 2009. What are Ford playing at?
One life, live it
dethleffs
Re: New Van Leaking Scuttle
Postby FrankK » Sat Jun 04, 2022 7:14 pm
Same problem with our 2018 Rollerteam. There is capillary transfer going on to where it’s falling onto the airbox. Seal with Screwfix gutter seal where it should drop down to the press on channel that goes over the inner wing. On the near side I put a cut down 2L coke bottle over the large multi connector by the ECU. Make sure the drain holes never block up.
The hard plastic clip that the scuttle clips into is part of the windscreen and can’t be bought.
I waxoiled everything around it to death.
Make sure the water hasn’t got to the injectors as replacement is a common problem on motorhomes. They fail anyway you just don’t want the added frustration of them rusted in place.
FrankK
Postby dethleffs » Sat Jun 18, 2022 9:55 pm
I’ve booked it to go into the Ford Transit centre to get it looked into.
I did think of a fix to stop it draining into the inner wings on both sides. If I pull off the plastic gutters on the ends of the scuttle, it reveals a round stub that a length of hose would fit on to drop the water down to the ground.
One life, live it
dethleffs
Postby workbox » Sun Jun 19, 2022 10:54 am
Same here throwed sponges out see no reason having.
workbox
Postby dethleffs » Thu Jun 23, 2022 8:43 pm
I’ve taken a couple of pictures before it goes in to dealer.
One life, live it
dethleffs
Postby KevofCov » Tue Jun 28, 2022 8:59 pm
May be of use, the bonnet hinge is a known issue on the MK8
viewtopic.php?f=64&t=195795
KevofCov
Postby dethleffs » Mon Jul 25, 2022 5:56 pm
It’s been to Stoneacre Ford in York today. They have replaced all the matting under the bonnet and the scuttle assembly. Tested it at home with some water, still leaks like a sieve. :roll:
I’ll have a go myself with some butyl rubber sealant on the wiper grommet and extend the passenger side gutter into the inner wing area. Not impressed.
One life, live it
dethleffs
Postby man le-mans » Wed Jul 27, 2022 9:42 am
You would think this would have been sorted by now it’s been a problem for years since they first come out in 2014
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Postby Sparkey_10 » Wed Mar 08, 2023 6:34 pm
Hi,
I also have a 2022 Chausson version Transit, with leaking windscreen/scuttle. I have fixed up the sides, to improve drainage, but the centre area drips onto the air filter case.
As it is under warranty I have visited 3 different transit service centres, and harassed my original supplier. I have also contacted Ford Fleet service centre at Laindon who advised me that it is designed to be a wet area in the engine compartment.
As far as I am concerned the vehicle is not fit for purpose in this state, because unfixed water ingress will damage the electronics, injectors, and possibly ingest water in through the air intake.
I am wondering how anyone else has managed to get satisfaction from Ford with this issue.
Sparkey_10
Postby Scottt350 » Sat Mar 11, 2023 5:17 pm
by the age of 8 their almost dead due to water ingres as im now finding out. ford dont give a damn. if you have a rwd also watch out for drainage right over turbo which seizes the actuator as i also found out.
Scottt350
Postby Festa » Sun Mar 19, 2023 8:18 am
If its leaking from either end of the scuttle and water running down onto the air box one side and ecu the other, theres is a fix from Fords. Its a deflector that directs the water away, they are different for each side these I believe are the part numbers
Drivers side 1927680
passenger 1936723
Theres an older post about it viewtopic.php?f=64&t=205472&p=1721516&hilit=leaking+scuttle#p1721516
Mine was pissing water over the ecu, its maddness that Fords actually sold the vans with this issue!
Festa
Postby Blizz » Mon Mar 20, 2023 12:14 pm
My van is a 2022 and have those "funnel" parts and there is also water over the air filter box and mould in the insulation foam in the wheel wells...
Not sure those parts cure the problem.
David
Blizz
Postby austieman » Thu Mar 23, 2023 2:08 pm
dethleffs wrote:It’s been to Stoneacre Ford in York today. They have replaced all the matting under the bonnet and the scuttle assembly. Tested it at home with some water, still leaks like a sieve. :roll:
I used some butyl tape on mine and it made a huge difference. Having already had 4 seized injectors and a cracked cam carrier I am very keen to keep the water of the airbox and engine. The butyl tape has redirected the water to the outlets and the funnels so its now just a case of keeping all the clear.
Mk8 L3H3 2.0L
austieman
Postby Blizz » Thu Mar 23, 2023 2:31 pm
Do you have pictures or can paint in some where did you used the butyl?
Blizz
