Mk8 62mph speed limiter
Postby Tjdmanandvan » Tue May 24, 2022 9:39 pm
Hello does anybody have any advice
Bought a 2014 2.2 125bhp jumbo today van is a minter however has been limited to 62mph from factory and has completely ruined my exitment of buying a van haha
Can anybody shed some light
Thanks in advance
I have a working forscan setup but have never tackled a limiter before
Tjdmanandvan
Re: Mk8 62mph speed limiter
Postby Blizz » Thu May 26, 2022 9:25 am
If you've Forscan then it's super easy to change the value.
Cheers,
David
Blizz
Postby Altransit » Thu May 26, 2022 9:50 am
Strange thing is that 62mph is a Minibus limiter, I wonder why it's on a van :?: :?
Postby Tjdmanandvan » Thu May 26, 2022 12:14 pm
I have forscan yes but have looked in main module it's already set to no speed limiter
Also checked bcm for line 7E0-01-04 but its none existent
62mph driving me mad
Tjdmanandvan
Postby Frag » Thu May 26, 2022 7:17 pm
You can also set a speed limiter in the PCM service functions.
You can set it in both that and the bcm,it will kick in at whichever is set lowest.
When you say jumbo…
You don’t mean twin rear wheel and over 3500kg ?
Frag
Ford Technician
Postby Tjdmanandvan » Thu May 26, 2022 8:04 pm
Frag wrote:You can also set a speed limiter in the PCM service functions.
When you say jumbo…
It's a xlwb t350
I have tried bcm can't find the line to edit also the main is set to no limiter but.only does 62 might.jusy get a remap guy to do it nobody seems to know
Tjdmanandvan
Postby The_crazed_one » Mon May 30, 2022 10:04 am
I tried a remap place. They couldn't remove the limiter on my 2.2 jumbo minibus. I will check the PCM module services. I would recommend a remap though. It would help to rev higther and reduce EGR anf DPF issues.
MK8 460 155ps L4H3 Minibus. Not converting it (yet)
The_crazed_one
