by Sam123 » Thu Jun 16, 2022 11:50 am
Did you use a decent quality EGR valve, e.g., Pierburg? If you used an ebay special, I'd probably change again with a Pierburg part just to be sure (don't cost much more than £100).
Check/replace air and fuel filter.
Check air inlet hoses for leaks. When I bought mine it had a leak where the crankcase breather pipe joins to the inlet pipe, just after the airbox. Although that didn't seem to actually be causing any running problems.
Check engine mounts.
After the above, my guess would be injectors. I don't usually like blaming injectors, they seem to get unfairly blamed often presumably because they are a nice, reasonably contained and profitable job to replace. But in this case does sound like a probable candidate.
Dual mass flywheel failure is another possibility, but I'd probably consider that last.
