Sam123 wrote:11.5 mpg does sound problematically low. At a rough guess, I'd have thought I average 25+ mpg even around town. Perhaps get each of the wheels up off the ground and check you haven't got brakes dragging.
Altransit wrote:There's a breather tube, attached to the tank, which is prone to splitting, and leaking fuel when the tank is full. Maybe yours has been doing this
Willber37 wrote:Have you tried a diagnostics tool such as forescan?
What about injectors? I will use these every now and again :https://www.ebay.co.uk/itm/283935639086 ... Swal5YGJOV
Johnler wrote:Willber37 wrote:Have you tried a diagnostics tool such as forescan?
Tried no codes stored, so don’t no where to go from here, I was hopping on a code or two
Not tried the cleaner, might be worth a try, never thought about this
Users browsing this forum: Blizz
