Engine Service Now!!
Postby andilicious » Mon Jun 20, 2022 7:01 pm
So is there any guidance as to what would cause the van to go in limp mode and display this on the screen?
I have reset the service counter and it runs absolutely perfect for a few miles and then back to limp mode and Engine Service Now on the dash.
This morning I turned it on and there’s no check engine light or any sign of the need to service the van immediately.
I have it booked in for next week to be plugged in and checked what the codes are but just intrigued to see if this is a common problem. It is also getting a full service as well whilst in as the van is due it on time not mileage.
Sent from my iPhone using Tapatalk Pro
andilicious
Re: Engine Service Now!!
Postby Sam123 » Tue Jun 21, 2022 8:14 am
That's a catch-all fault message - it could be almost any fault. Likely candidates are turbo actuator or EGR.
Sam123
Postby andilicious » Tue Jun 21, 2022 8:57 pm
Sam123 wrote:That's a catch-all fault message - it could be almost any fault. Likely candidates are turbo actuator or EGR.
Great. This happened on the drive home from buying it so either of them 2 things I’ll be pushing back to the seller I think!
andilicious
Postby KevofCov » Tue Jun 28, 2022 9:09 pm
I agree - you should be batting the problem back to the dealer (I'm assuming it's a dealer - private sale your on your own). Going forward get yourself a code reader, there're super easy to use and you can't bugger up your van using them.
KevofCov
Postby andilicious » Tue Jun 28, 2022 11:11 pm
KevofCov wrote:I agree - you should be batting the problem back to the dealer (I'm assuming it's a dealer - private sale your on your own). Going forward get yourself a code reader, there're super easy to use and you can't bugger up your van using them.
Have you a link to a decent code reader? Never sure of what to buy!
andilicious
Postby Funkyjazzlover » Mon Aug 01, 2022 10:08 am
It came up regularly on ours while in France while doing motorway drives (not something we do much in the UK) within half an hour of starting.
After some searches I expected it to be the MAF sensor, but after getting the codes scanned it turns out it was the DPF which wasn't re-genning properly. I should add the DPF light never came on.
Funkyjazzlover
Postby Harry2479 » Fri Sep 02, 2022 4:35 pm
I am also getting this msg had it plugged in and its says its low temperature on regeneration on sensor Bank 1 of the dpf.
Harry2479
Postby dumper » Fri Sep 02, 2022 7:43 pm
When mine wouldn’t regen it was the thermostat that replaced and sill ok
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
