steve58 wrote:Had the same message of. Engine service now. On my van ,it turned out to be the sensor on the left side of the intercooler, changed it ,only cost a couple of pounds, problem solved hope this helps
Volksfish wrote:steve58 wrote:Had the same message of. Engine service now. On my van ,it turned out to be the sensor on the left side of the intercooler, changed it ,only cost a couple of pounds, problem solved hope this helps
I have the same , could you point out which sensor it is, cheers.
