FOB remote programming
Postby Blizz » Mon Jul 11, 2022 8:02 am
Hello,
Yesterday suddenly both my remotes quit working. I still have to check the fuses (There's one for the remote receiver and telematics) but could not check yet.
Anyways, do you know how to program a remote on a 2022 mk8? I tried cycling 8 times the ignition but nothing happened... There's no option on FORScan either.
Thanks,
David
Blizz
Re: FOB remote programming
Postby Altransit » Mon Jul 11, 2022 10:13 am
If the key starts the van, then the remote is programmed, there's no individual programming on these. The turning on and off thing was for the Mk6 which had a separate key and remote locking fob.
:idea: If your van has two batteries, check that the aux battery still has power (unlikely on a new van, but costs nothing to check).
Postby Blizz » Mon Jul 11, 2022 10:31 am
Good to know that the key and FOB can't be "separated".
Will check the fuse #31 on the BCM wich says Data link connector. Remote key receiver.
I will update.
Thanks,
David
Blizz
Postby Blizz » Thu Jul 21, 2022 7:47 am
Well, just in case anyone has the same problem than me...
During the first ride after the remote issue a TMPS sensor error appeared. That made me think... "What did you do before the error?"
I lowered the cabin trim for insulating (Could not remove it completely due to lots of wires) and then thought... "Maybe I disconnected something before deciding not to remove it completely?"
Answer was yes, I did.
There's a plug in the roof console, that is the remote and TPMS receiver. Plugged it again and voilà, all works as shoud.
Cheers,
David
Blizz
Postby Altransit » Thu Jul 21, 2022 8:33 am
That fits well with the old adage "If there's a fault, always check the last thing you did" 8) :mrgreen:
A good spot of diagnosis :D
