Evening all, my mk8 decided to blow the turbo last week, 148,000 on the clock, sounded like I’d ran over a crisp packet, so I’ve been out and replaced the complete turbo inc actuator, I’ve also replaced the oil feed pipe and return pipe. Now here’s the fault, cleared all the codes and it’s coming up with P2564-00 Turbocharger boost control position sensor circuit low- current DTC warning lamp on
When the engine is running the boost sensor is saying 1.7volts and if I unplug it it says 5volt, I’ve cleaned it but still nothing, the Boost Pressure Actuator Output sits at 0.00%, do you think the pressure sensor is naffed.
Thank you all as it’s now doing my head in.
